When I try to record in FLAC (regardless of settings) with V8.5-64 b6067 I get a file, but it cannot be edited in sound forge, when loaded into winamp it will play but the total time is always 0 and there is no playback head for scrubbing
The file loads ok in Virtual DJ
When I record in FLAC with V8.4 b5874 the file is fine, can be loaded into sound forge, playback head and total time shows up in winamp
I also tried recording on a different pc with the same results
Maybe a rollback to any FLAC recording changes could fix this?
Any help on this situation would be greatly appreciated!
geposted Wed 19 Aug 20 @ 3:46 pm
Something else to note, FLACS's recorded by the latest build have cue points built in to identify the songs, where the old version didn't do this, maybe this is the issue?
geposted Wed 19 Aug 20 @ 5:31 pm
Can you try the latest Early Access release? (6067)
geposted Thu 20 Aug 20 @ 11:08 am
Do you have a link to build 6076? I can't seem to locate it
Edit: I found it here https://www.virtualdj.com/download/build.html
geposted Thu 20 Aug 20 @ 1:20 pm
geposted Thu 20 Aug 20 @ 1:21 pm
Flac looks like it's working well in this build!
Great job!
Great job!
geposted Thu 20 Aug 20 @ 1:32 pm
