I have been using the same syntax for filtering by key since I started using the program, but I noticed today that in version 6067 that this query is returning wrong results.
Here is the string; key is "02A" or key is "02B" and exists = 1 (or it can be key is "03A" or key is "03B" and exists = 1 whatever key you are searching for.)
This search has always return songs in 02A and 02B. But now the search is returning songs in 02A and 11A.
If you try a simpler search such as key is "04B" the results will be songs in 01A.
So, it seems that a search for a key that ends in B is returning songs that are 3 numbers lower and end in A.
Please advise, as this is not a good situation.
Thank you.
Thank you.
geposted Thu 20 Aug 20 @ 5:20 am
Works correctly here.
keyDetection is set to broad range?
Are you using getKeyFromTag option?
geposted Thu 20 Aug 20 @ 5:39 am
Thanks!
Switching keyDetection to broad range instantly fixed the problem.
geposted Thu 20 Aug 20 @ 3:18 pm
That's good - but why should setting it to 'electronic' give you results outside the filter range?
@Adion I suggest (again) that the 'electronic' option is removed from the VDJ settings. It causes trouble rather than serving any useful purpose now.
geposted Thu 20 Aug 20 @ 3:43 pm
I agree with you groovindj
It makes no sense why changing that setting should have anything to do with a simple filtered search. AND, I am fairly certain that I have always had the setting on "electronic" before this.
But at least I am back to how it has always been for me.
geposted Thu 20 Aug 20 @ 4:49 pm
Its a bit of left-over from older versions, where it was "electronic" was the standard, if I remember right ;-)
A bit like other "transitional" settings, where you can keep "using old" if the change to new version appear "too drastic" ;-)
Just set it to broad-range :)
geposted Thu 20 Aug 20 @ 8:01 pm
Thanks for the info, Rune!!
geposted Sat 22 Aug 20 @ 4:56 pm
