The LPD8 worked perfect in VDJ 8 with a custom mapping.
When I launch VDJ20212, the controller is recognised but the mapping is not loaded. No worries, I entered the mapping manually, again, but the controller is not picked up by VirtualDJ. At one point I got an error message when starting VDJ saying something that the interface is not midi compatible (It is, of course).
How can I get this interface to work again under VDJ2021? Every time I go back to VDJ8, it works without problems. But it just refuses to load under VDJ 2021.
geposted Thu 20 Aug 20 @ 9:07 am
Make sure everything on the LDP8 is set to default - use the LPD8 Editor to set it.
geposted Thu 20 Aug 20 @ 9:13 am
Thanks for the info. I managed to get it working again.
In the LPD8 editor, the configuration shown is the default configuration. Just write that preset to a program you want to use and then load that program when entering VDJ2021.
You have to do the mapping all over again.
geposted Thu 20 Aug 20 @ 9:38 am
geposted Thu 20 Aug 20 @ 9:45 am
Thanks!
Also note the sliders need to be renumbered. They are 0-7 in the Akai default mapping but 1-8 in the VJD2021 mapping.
It's fixed and I'm happy!
geposted Thu 20 Aug 20 @ 9:51 am
