VDJ 64bit b6067, Windows version, had a bug (not show it) on waveform upsidedown of Deck 1 or Deck 3 (not scratchwave, but rhythmzone wave type); Deck 2 or 4 are Ok.
With 32bit version work ok on all decks.
geposted Fri 21 Aug 20 @ 9:39 am
Uhm, I think my bug report it's not interesting.
geposted Tue 25 Aug 20 @ 8:24 am
It doesn't look like the default skin
So you should probably test it on the default skin
If you don't see the issues on that skin, you need to talk to the guy who created the skin, and have him fix it
geposted Tue 25 Aug 20 @ 8:36 am
I don't think the default skin offers an inverted wave.
geposted Tue 25 Aug 20 @ 8:43 am
I'm the author of this skin; if there's an issue with skin, I'm exptect not working on 32bit of VDJ: but work correctly
Not work correctly only on 64bit version.
In the default skin there isn't this wave type (Rythmwave Upsidedown), so it's not reproducible with it.
geposted Tue 25 Aug 20 @ 8:51 am
You may need to look into all the changes there were made to the skin engine then...
But you'll probably need one of the devs to get the full info
(But those changes were mostly done for VDJ2020, I think)
geposted Tue 25 Aug 20 @ 8:53 am
So you say seriously that there's a different syntax of VDJ script from 32bit / 64bit ?
geposted Tue 25 Aug 20 @ 8:56 am
