Hello,
(sorry for my limited english)
Since the last update, I have detected 3 small bugs, which do not affect the mix. I haven't done extensive testing, but here we go:
1) Freezing of records.
The WAV format, after a random time, freeze recording, still showing "recording", but the timer counter freezes, and the size of the WAV file too.
I tried 3 times: one stopped after 15 minutes, one after 3 minutes and once after only 21 seconds.
No settings have changed since the automatic update. And I always record my sets (no problem last week in the previous version).
This is the most serious bug for me, because I record my podcast this way, live mixing.
2) Auto-change of PFL after some time, after the "new" song plays for a few seconds.
Maybe a new feature, but it seems strange, before I select the new song, while listening to the current song on the master + pfl, the pfl automatically alternates (to the other deck) for no reason, so, sound disappear on my phone.
3) VDJ 2021 + OBS / Streamlabs
Not b6067, but since the first launch of 2021. I transmit (live video stream) my webcam + the VDJ screen and my DJ logo, to a RTMP server.
In VDJ 8, in OBS, I can "capture window" in automatic mode, without problems.
In VDJ 2021, I had to switch to Windows Graphics Capture, which also grabs the mouse pointer and, several times, the VDJ image freezes in OBS, I need to change to another frame to fix it. Difficult to explain, but something has changed and I cannot find a way to grab the screen correctly.
NOTE: I use Hercules 4-MX console, but don't seems to be related.
Thank you.
Thank you.
geposted Sat 22 Aug 20 @ 2:35 am
1 has been fixed with EA
2 check settings for PFL
3 that happens with OBS when gfx is pushed too hard, stems push gfx quite hard.
geposted Sat 22 Aug 20 @ 4:46 am
Hi there,
1- the problem has been fixed for a new release not ready yet? Mine is still B6067. Sorry, I don't know what "EA" means...
2- I'll search
3- I'm not sure what to do, if you have any tips...
2- I'll search
geposted Mon 24 Aug 20 @ 6:31 pm
ea = early access
3 you could switch stems calculation to CPU to avoid applying stress to your GPU
geposted Mon 24 Aug 20 @ 7:00 pm
If you want to test and use EA version you can do so by downloading installer below, and run it as is, to update the software ;-)
PC: https://www.virtualdj.com/download/pc/ea
Mac : https://www.virtualdj.com/download/mac/ea
Keep in mind this is a "public beta" sort of version, so if you are doing gigs, and its not crucial to have any fixes already, better to wait for public release.
geposted Mon 24 Aug 20 @ 7:06 pm
Ah, ok, thanks. I prefer wait the public version, since I do live mixing...
I'll check about the stems and cpu usage.
Thanks for the tips.
geposted Mon 24 Aug 20 @ 8:00 pm
