Topic: beat grid in soundswitch
hello guys i am trying to use sound swtch to control my lighting but i cant establish a beatgrid i have analyzed my files a thousand times but SS wont read it now soundswitch says its your problem with the software but i don't think so any ideas?thanks
geposted Tue 25 Aug 20 @ 2:56 am
Think the SoundSwitch software will try import beatgrid from the DJ software, but if failing to do so, you can beatgrid in SS
https://support.soundswitch.com/hc/en-us/articles/217585178-Beatgrids
And for later songs added, you probably have to make SoundSwitch import VDJ again, but not sure.
With OS2L VirtualDJ will send the beats to SS though.
Havent used it myself, and havent dived into how it works, but maybe this guide will get you started:
