Topic: Virtual DJ not recording
I have been recording mixes problem free for months now and I just updated Virtual DJ, now, when I press record it records for a second or two, then the timecode freezes (the one showing how long i've been recording for). I then have to press stop record, but it only recorded whatever was happening up until the timecode froze. Any help? I am using a DDJ-1000 (rekordbox) with the most recent VDJ update. Im so frustrated right now.
geposted Tue 25 Aug 20 @ 8:45 pm
Hey man. I am facing the same error. Can you please share the solution if any
geposted Sat 19 Dec 20 @ 4:48 pm
What if you try record to a different location.
For example desktop?
Perhaps its something with the path
geposted Mon 21 Dec 20 @ 2:28 pm
saulHome userMember since 2020
Same issue. The file starts records to 733kb and then finishes at 1.33MB. Looks like it's recording but it's not. First time recording since the update and it's a nasty nasty bug, and an epic 90 minute mix didn't record :( .
geposted Mon 21 Dec 20 @ 9:42 pm
Hi, I record an hour long mix only to find out the mix was not being on my laptop. I don't know if it is because on the file name I used this symbol [:] as part of the name of the file.
Is there any possibility that I can retrieve the mix that I was recording??
geposted Tue 31 Aug 21 @ 2:24 pm
geposted Tue 31 Aug 21 @ 3:36 pm
