Hello, friends
How can I configure my browser so that when columns order in one playlist change, they change in other playlists?
Best,
Pavel
Best,
Pavel
geposted Wed 26 Aug 20 @ 3:42 pm
in settings, turn on keepSortOrder
(if you meant the sort order. The column order is already same between all views)
geposted Wed 26 Aug 20 @ 7:53 pm
I use a deezer and filter folders, and between them the order of the columns is not synchronized, I need to manually set each new filter folder
geposted Thu 27 Aug 20 @ 8:28 am
I have to manually set the order of the columns in each new filter folder
geposted Thu 27 Aug 20 @ 8:29 am
