trying wierd things with stem:
-taking advantage of crossfader starts all decks from the same deck class when fader_start is on
-taking advantage of the facts VDJ shares same track loaded between decks (no overload)
-mixerOrder set to 1234 and decks
-1 2 3 4 affected to left crossfader
and using 8 decks skin
deck 1 load & stem_pad isolate rhythm & deck 2 load & stem_pad isolate bass & deck 3 load & stem_pad isolate instru & deck 4 load & stem_pad isolate vocal
(may adjust load twice to get the right mode because no way to toggle stems in a specific state)
this loads the track 4 times and respectively affect rhythm bass instru & vocal only to decks
move crossfader start all the decks in sync and this way each deck can control one stem only
this alllows to apply filters to only one stem , mute, eq ....
geposted Thu 27 Aug 20 @ 1:53 am
FIX , to make a correct StemLoad button :
deck 1 load &only_stem rhythm & stem_pad rhythm & deck 2 load & stem_pad isolate bass & deck 3 load & stem_pad isolate instru & deck 4 load & stem_pad isolate vocal
the StemStop :
deck 1 stop & deck 3 stop & deck 4 stop & deck 2 stop_button & clone_deck 1 & clone_deck 3 & clone_deck 4
the StemPlay:
crossfader 100% & crossfader 50%
the StemStop :
the StemPlay:
geposted Thu 27 Aug 20 @ 5:40 am
