Topic: Headphones/Cue won't work since update
jliconaPRO InfinityMember since 2011
I'm running a DDJ-SZ2 through the new virtual dj pro, and headphones wont work now. What do I need to do?
geposted Thu 27 Aug 20 @ 4:33 pm
Mac or PC?
Is the audio config set as per SZ2 setup guide?
You should be getting a detection popup when connecting the SZ2, on which you need to OK the sound settings. If you didn't get that or didn't OK the settings, there's a dedicated SZ2 button in the audio config area which you can click.
geposted Thu 27 Aug 20 @ 4:57 pm
groovindj wrote :
Mac or PC?
Got it thanks!
geposted Thu 27 Aug 20 @ 4:59 pm
