Topic: Mapping reverse to Rane Seventy pad
Hi everyone!
I'd like to modify some pad functions but I can't get reverse mode (playing the track backwards) to work.
I put in
pad_pages 12 ? pitch_reset: pad 1
so pad 1 resets pitch if in transport mode and it works just fine, but even if I just put in reverse without any shenanigans for pad 2 it doesn't do anything, so I assume my problem is with the syntax for reverse.
Does anyone have experience with this?
geposted Sat 29 Aug 20 @ 11:12 pm
Leave the pad action as is (default action) and edit the Transport pad page instead
Thank you very much djdad!
I'm super embarrassed, but I cannot find where to do that - can you please help? Version is 8.5-64 b6067.
Also: do I have to consider sth. in particular in order to set reverse mode?
Okay, nevermind - I use my own skin and thought it would be in the settings:
'https://www.virtualdj.com/manuals/virtualdj/editors/padseditor.html
