It would be really handy in the tag editor if there was a swap feature i.e. swap ARTIST and TITLE or swap ARTIST and ALBUM name so that karaoke files that are interpreted wrong from ID3 tags can be quickly put into the correct format. Other than that the software is BRILLIANT and keeps getting better with each update!!
geposted Sun 30 Aug 20 @ 3:51 am
Already available.
Open Tag Editor, at the bottom File Info, to the right of the filename there is a dot menu.
While you're there you can also Fill missing info from Discogs (works from the correct Artist & Title).
geposted Sun 30 Aug 20 @ 8:47 am
