Dear VDJ Team,
I just downloaded the new release and i saw this in changelog :
BUILD 6067 (2020-08-16)
-Rane Twelve MKII support
-Rane Seventy Two MKII support
-Echo Out effect added
I have been waiting a long time for the echo out :)
However in the effect list, i don't see the echo out. Should i assume that pressing "Mute source" has the same effect.
What is the use of "trailing stop" button ? I didn't notice any difference with or without.
Have you udpated the VDJ user guid with these new fonction ? because i have been looking and haven't find any documentation.
Do you have any values recommended for good results of the effect ?
Thanks !
Thanks !
geposted Sun 30 Aug 20 @ 10:15 am
that isn't echo out, you're looking a echo there, you need to install echo out.
trailing stop is related to echo fx being switched off
geposted Sun 30 Aug 20 @ 11:08 am
There seems to be something wrong with the Echo Out effect.
I've just been messing around with it, and I'm getting a loud knocking sound in sync with the echo, with the controls set so:
Feedback 81%
Length 1bt
Color >5%
Reverb 0%
Feedback 81%
Length 1bt
Color >5%
Reverb 0%
geposted Sun 30 Aug 20 @ 11:47 am
hi, thanks for answering. How am i supposed to install it ?
geposted Mon 31 Aug 20 @ 11:49 am
this explains extensions
https://www.virtualdj.com/manuals/virtualdj/settings/extensions.html
geposted Mon 31 Aug 20 @ 12:04 pm
geposted Mon 31 Aug 20 @ 1:38 pm
