Topic: Search bug
Hello,
in the latest VDJ 2021 (8.5-64 b6067) I found a bug in the track search function.
If you set to search in local folder and not in Global DB the program won't find anything (at least on my install) - attached you see the search settings.
In order to find something I have to se Global DB search = Yes
geposted Wed 02 Sep 20 @ 1:22 pm
NicotuxHome userMember since 2014
Tested here, everything is fine 'b6091'
With the same request only "Other folders" area disapear when disabling "searchInDB"
of course when disabling "searchInDB" the specific area for "inCurrentFolder" does not appear, the files in the folder appear in the list as any other
only empty when search does not contains any file matching the search fields
geposted Wed 02 Sep 20 @ 1:49 pm
Now working perfectly - so that's OK.
I'm sorry, I have tried at least 5 times before posting.
This time I tweaked search options from the Browser section instead of making a keyword search on the settings. Anyway it's OK for me.
geposted Fri 04 Sep 20 @ 5:09 pm
