Topic: Encoder Mapping Troubleshooting
Hi
I applied this old encoder "loop move" mapping previously used on a Novation Twitch, to a Denon MCX8000.
The encoder on the Denon is mirrored on both sides.
It worked perfectly for a day, then the mapping stopped working on the left screen encoder.
The mapping still works on the right screen encoder
I've remapped other functions to the left side encoder, all successful, so it doesn't seem to be a hardware issue.
I've tried all the usual unplugging, restarting, even factory reset the controller...
Any thoughts on what might be going on here?
Thanks in advance...
Here's the script:
loop_select 0.03 ? param_smaller 0 ? loop ? loop_move -100% & goto -0.03125 : goto -0.03125 : loop ? loop_move +100% & goto +0.03125 : goto +0.03125 : loop_select 0.06 ? param_smaller 0 ? loop ? loop_move -100% & goto -0.0625 : goto -0.0625 : loop ? loop_move +100% & goto +0.0625 : goto +0.0625 : loop_select 0.12 ? param_smaller 0 ? loop ? loop_move -100% & goto -0.125 : goto -0.125 : loop ? loop_move +100% & goto +0.125 : goto +0.125 : loop_select 0.25 ? param_smaller 0 ? loop ? loop_move -100% & goto -0.25 : goto -0.25 : loop ? loop_move +100% & goto +0.25 : goto +0.25 : loop_select 0.5 ? param_smaller 0 ? loop ? loop_move -100% & goto -0.5 : goto -0.5 : loop ? loop_move +100% & goto +0.5 : goto +0.5 : loop_select 1 ? param_smaller 0 ? loop ? loop_move -100% & goto -1 : goto -1 : loop ? loop_move +100% & goto +1 : goto +1 : loop_select 2 ? param_smaller 0 ? loop ? loop_move -100% & goto -2 : goto -2 : loop ? loop_move +100% & goto +2 : goto +2 : loop_select 4 ? param_smaller 0 ? loop ? loop_move -100% & goto -4 : goto -4 : loop ? loop_move +100% & goto +4 : goto +4 : loop_select 8 ? param_smaller 0 ? loop ? loop_move -100% & goto -8 : goto -8 : loop ? loop_move +100% & goto +8 : goto +8 : loop_select 16 ? param_smaller 0 ? loop ? loop_move -100% & goto -16 : goto -16 : loop ? loop_move +100% & goto +16 : goto +16 : loop_select 32 ? param_smaller 0 ? loop ? loop_move -100% & goto -32 : goto -32 : loop ? loop_move +100% & goto +32 : goto +32
geposted Wed 02 Sep 20 @ 1:25 pm
btw - I also tried applying the mapping to SHIFT+Encoder
Same result... right side works, left side doesn't.
Cheers.
