Not exactly sure how to describe it, but this always seems to happen if I change to window format and I can't figure out why. Nothing except restarting the program will fix it. Any ideas?
![](/img/320378/4679/Screen Shot 2020-09-04 at 5.05.12 PM.png)
geposted Sat 05 Sep 20 @ 12:08 am
yes there are sometimes issues with window resize in some case (i.e.: when some different skins have been used in same session)
you can workaround this by doubleclicking resize zone (bottom right corner) in a way to reset initial settings then resize and save settings (or restart VDJ)
geposted Sat 05 Sep 20 @ 12:19 am
WFUSDF wrote :
Not exactly sure how to describe it, but this always seems to happen if I change to window format and I can't figure out why. Nothing except restarting the program will fix it. Any ideas?]
Changing screen resolution or dpi then I guess?
A restart of the program is probably needed then
geposted Sat 05 Sep 20 @ 8:32 am
When he says "change to window format" he's simply clicking the maximize button to switch between running VDJ full screen or "windowed" (floating).
geposted Sat 05 Sep 20 @ 8:54 am
