Hi there,
when i edit something (a.e. some ID3 tags), i need to take my mouse into the hand and move it and klick to the "OK" button. This is ok when im at home. If would be nice if the form will be saved and closed with the Return key on the keyboard. Then i can edit it better during the gig.
Return key -> save and close
Escape Key -> close without saving
geposted Sat 05 Sep 20 @ 5:48 pm
its not user friendly but it is not totally impossible :
OK button have to be select using TAB or shift+TAB key then return/enter/Space key is working
also working with other buttons (prev,next, write tags), or combo (color) but not with options
Escape is .... undoing nothing but the last action (last entrie in a text input area) really unusefull
geposted Sat 05 Sep 20 @ 6:14 pm
esc works, return used to confirm & exit for tag editing
a lot of the tag editor key shortcuts are ALT+ but ALT+RETURN is hooked into some useless full screen short cut, not sure if it's windows or some now dead backcompat type of thing, I can say ALT+RETURN when tag editing is an absolute show stopper, I've brought it up before, maybe it was missed
geposted Sat 05 Sep 20 @ 6:18 pm
Just try ALT+ENTER waow ^^ .. really is an absolute show stopper ... VDJ hangs in some wrong screen resolution, don't kill, don't give screen to another app, very hard to go back to usable session
As windows does not do this out of VDJ, it's not a nVidia / Windows shortcut
geposted Sat 05 Sep 20 @ 7:00 pm
Alt+Enter was indeed supposed to work for this, but looks like DirectX 11 likes to take over this combination by default...
Will fix for next update.
geposted Sun 06 Sep 20 @ 11:48 am
