I have a DDJ-SB3 and when I connect it to VirtualDJ it doesn't work. When I am just using my laptop with VirtualDJ the stems work fine. Any assistance would be appreciated. Thanks
geposted Sat 05 Sep 20 @ 8:42 pm
Doesnt work WHERE?
In other words, how are you using it? EQ, pads? audio fx?
At top of the EQ section (in the skin) there is a drop down arrow, you can set what the EQs should do, might be the one you tried use perhaps.
geposted Sat 05 Sep 20 @ 8:43 pm
