IIDEEJAYII wrote :
Thank you Nicotux.
Wow, I can now move virtual folder to the New virtual Subfolder I created.
Still cannot move a virtual folder into the Target virtual folder, but only into a subfolder within the Target folder. (so its 2 levels down, nested)
Is that what you are saying ?
Thanks again
And also good to know that I am not the only one, who is unable to move a virtual folder, to inside of another.
Thanks all for the help.
Thanks again
Hiya,
I am also having trouble with folders, it's a very similar issue except that any virtual folders I create become subfolders of pthers, even when I choose the root option and then I can't make them a main root folder, not even by dragging them across to the left.
This must be part of the same problem.
Any advice greatly appreciated!
geposted Wed 30 Dec 20 @ 9:45 am
Hi have been wanting to reply, and distracted with many things.
I can easily create a virtual folder any where I want.
(now its the only way to move a folder to a subfolder, create folder in subvirtual folder and duplicate entries and delete original)
Here is screenshot to create virtual folder in Root Directory of Local Music. (one can create virtual folders in many locations, like LISTs and ADVICE, FILTERS, MUSIC etc,)
virtual folder.png" class="bb-img">
Let me ask, do you have same names for folders for your Music on your Hard Drive, then created Favorites to those folders in VDJ?
I noticed that doing that, caused the virtual Sub-folders to be duplicated in that Favorite folder, and maybe you are looking/working there.
Example: on hard drive I have Music in folder "Dance 80s" and if I create a Favorite in VDJ for this music folder .. AND then use the same name to create a virtual folder in root directory of "Dance 80s" (w subfolders in it) all the subfolders of the virtual folder, "Dance 80s", are duplicated in the Favorites folder, "Dance 80s". So the virtual Subfolders appear in 2 locations in VDJ.
Not an issue, but may behave differently, if one was using them to add or modify virtual folders, there.
geposted Sat 09 Jan 21 @ 8:07 pm
I have the same issue. It's happening with playlist folders as well. See the video here:
https://vimeo.com/557628292
geposted Tue 01 Jun 21 @ 2:52 pm
Is there still not yet a fix for this?
geposted Wed 05 Apr 23 @ 8:27 am
It seem NOT, there is still NO easy way to move a virtual folder 1 level down.
Seems like this should be an easy tweak
(to have VJD, use the move action, to trigger a change/write to the "order" file, in these circumstances).
(the hard way, and NOT recommended is to edit the "order" file, directly, from the OS (with Notepad or Notepad++) located in Documents > virtualDJ > folders folder.)
Much easier (and not elegant) way move a virtual folder 1 level down, (to make a subfolder) is to create a NEW subfolder 1 level down, with the same name and copy all the tracks to the new virtual folder and then delete the old one.
One CAN move a virtual folder 2 levels down.
Win 10
7512
Win 10
7512
geposted Wed 05 Apr 23 @ 8:59 am
I replied to this problem a couple of years ago (can't find the post).
It's all about the red line, that is with the default skin, just tried on another skin and the line is not red, but, returning to the default skin and it's there.
The secret is when dragging a list or folder to drop, hold onto the mouse button and move the mouse pointer left and right in the folder window and you will see the red line change from a straight line to a line with the triangle on it, then, ONLY release the mouse pointer with the desired line for what you want to do. I've just tried it moving a virtual folder inside another virtual folder and moving it back out, works fine. I have to say it is very tricky to do, but, if you are careful where you release the mouse button it does work as in the manual.
folders i n VDJ.png" class="bb-img">
I'm on a Mac btw using the mouse pad.
OK, I've just dragged out my bootcamped Mac and tried it on the Windows version and can confirm it is working fine on there too. I can't find a HIDE folder command on either system.
My Systems Specs;
Main - M1 MacBook Pro (14-inch, 2022), Apple Silicon M1 Pro, 16gb, 500 gb SSD, macOS Ventura 13.3, virtualDJ v2023-m b7512.
External WD Passport Ultra 2Tb HD formatted exFat containing Music & Video databases.
Controllers - Denon MC7000, Denon MC6000 Mk2.
Backup - MacBook Pro 15-inch 2017 (Touch Bar), 2.9 GHz Intel Core i7, 16gb 2133 MHz LPDDR3 Memory, Radeon Pro 560 4096 MB, Intel HD Graphics 630 n1536 MB, macOS Ventura 13.3, 500gb SSD. NTFS for Windows installed. virtualDJ 2023-i b7512.
Bootcamped with Windows 10 Pro Vers. 22H2 x64bit.
My Systems Specs;
geposted Wed 05 Apr 23 @ 2:35 pm
Thanks Les for working on this:
And Yes, that is what the manual says.. If only VDJ worked the way the manual indicated, for at least the last 2.5 years it does NOT work that way. Hence the reason for the original post. Can NOT get the indicator that folder will move to subfolder, and of course it does NOT move there.
Maybe it works with Mac, but with my Windows 10 system, currently there is NO way to move virtual folder to make it subfolder.
As mentioned if there is already a subfolder that exists .. one can use the method described in the manual to move an upper level folder into the subfolder (2 levels down). But NO way to move a folder 1 level down.
Here are videos of having created 3 virtual folders TEST1, TEST2 and TEST3 as below:
folder start.png" class="bb-img">
1) attempting to move TEST1 to a subfolder of TEST3
(notice one never gets the indication it will move to subfolder and when released does NOT move to subfolder of TEST3, stays at the original level)
https://gyazo.com/079678cfda8033775ae9396d36483e4e
2) attempting to move TEST1 to subfolder of TEST2
(notice one never gets the indication it will move to subfolder and when released does NOT move to become a subfolder of TEST2, at same level as SUB2)
https://gyazo.com/2063eed5890dab126162a74695c6fa29
3) attempting to move TEST1 to subfolder of SUB2 (which is already existing subfolder of TEST2)
(notice one DOES get the indication of the move to a subfolder, and TEST1 is moved to a subfolder of SUB2, So one can move a virtual folder to an existing subfolder (now 2 levels down)) BIT NOT 1 level down.
https://gyazo.com/ce7e699b2904367e2cf8ef03041b4478
The above was done with NO controllers attached.
Win 10
7512
@Les you seem to have all the LUCK !
If anyone can move a folder one level down for an ordinary virtual folder, would love to see the video of it in action.
Maybe could get a poll of those who can get this to work and cannot. And their system configuration
PS
As mentioned 2.5 years ago .. there seems to be a few exceptions where it works
Started to wonder if it is dependent on the Path of the virtual folder.
If the Path is shown as [ROOT\............ it works...
If Path is \Users\USERNAME\Documents\virtualDJ\folders\........... it does NOT work
Win 10
7512
PS
IIDEEJAYII wrote :
can move a virtual folder into say a VDJ created folder such as Online Music or Filters or Lists & Advice and even Hard Drives
And in some cases the destination as to whether the it will be a Subfolder or Just ReOrdering can be done by the L and R positioning of the Mouse during the move. (more Left moves it into a Subfolder and more Right just ReOrders it)
see example Video
https://gyazo.com/7cf8e0b48f007270d4219d531c4ae146
In this case the choice to move into the Lists & Advice folder or below it.
see example Video
geposted Wed 05 Apr 23 @ 3:55 pm
no difficulty really, I had a harder time putting fav folders in to vfolders
geposted Wed 05 Apr 23 @ 4:09 pm
