Topic: Renaming file names
wizwychHome userMember since 2020
when i try to rename files names on the VDJ 2021 from the tag editor it constantly wants to add a ; instead of a lowercase L
example:
Elvis Presley - Are You Lonesome Tonight.mp3
becomes
Elvis Pres;ey - Are You Lonesome Tonight.mp3
geposted Thu 10 Sep 20 @ 12:25 pm
Those keys are right next to each other on the keyboard. Are you sure you're hitting the correct key?
geposted Thu 10 Sep 20 @ 12:27 pm
i have a picture of it doing it i'll upload to my website for you to view....
geposted Fri 11 Sep 20 @ 7:32 pm
If I had a penny every time I typed a semicolon on my laptop instead of an L - or any computer - I would be able to buy every company on the planet!
geposted Sat 12 Sep 20 @ 7:40 am
Test it by pressing just the one l-button several times without typing a complete word.
Then, test it at another software a.e. Wordpad editor.
geposted Sat 12 Sep 20 @ 9:25 am
Start simple, try another Keyboard. Could be an issue in that section of the keyboard.
geposted Sat 12 Sep 20 @ 4:28 pm
