Topic: new system
bogartPRO InfinityMember since 2004
setting new laptop. All mappers etc copied from old system.
Connected VMS5 it works. Problem is the key board shortcut
do not work. I have one key mapped to move
song to automix and one to move to sidelist. This worked on
older system but will not on new system. everything setup same.
When looking at mappers. The top left is supposed to be on
keyhboard and the far right should have Custom Mappig .
It shows keyboard as well. If I switch to VMS on left,
customs mappers appears on right. But is will not work either way.
Suggestions please.
geposted Thu 10 Sep 20 @ 6:38 pm
Not sure I fully understood what you meant, but you need to select your custom keyboard mapper at the drop down at right side..
geposted Thu 10 Sep 20 @ 7:26 pm
Yep.however there is no custom mapper in the drop down.
All mappers have been transferred to this system. If I go
to mappers it does show customs mapper. It just does not appear in VDJ.
Then only way custom mappers appear is if VMS is selected on the left side.
But that is not the correct way it should be.
geposted Thu 10 Sep 20 @ 7:34 pm
