It also says I have to register my controller, even though I did that months ago.
I can't use my controller now, since it's telling me to buy a license, even though I registered the device back in April.
geposted Fri 11 Sep 20 @ 3:56 pm
There is no license registered at your account, so thats probably why the software ask for a license with extended use.
Try enter the LE license code here for the PartyMix controller : https://www.virtualdj.com/users/licenses.html
And if that doesnt work, contact Support here https://www.virtualdj.com/help/ so they can help ;-)
If you get "invalid code" also check if you misspelled, or if you copy pasted some extra white space or something like that.
geposted Fri 11 Sep 20 @ 4:00 pm
