i have been gettin screen freezes for like 5 secs or so (seems like a lifetime lol)
the waves would start shaking in place and music stops then all is well again (untill it happens again).
thought it was external hd so replaced it but still same problem. now today if i right click a song or try and change settings (performance tab ,select tab , browser options tab , right click a song or a playlist ,vdj closes itself out and restarts
it does this with nothing connected at all
brand new Dell G3 3500
intel core i5-10300H @2.50ghz
16gb memory
256gb ssd
GPU nvidia Geforce gtx1650
CPU intel UHD Graphics
running vdj 6100 same results in version b6067 lookin for answers i tried going to this version as well as changing settings to settings.old
same results
16gb memory
256gb ssd
same results
geposted Fri 11 Sep 20 @ 9:37 pm
geposted Fri 11 Sep 20 @ 9:45 pm
Also tried with math engine disabled ..same results smh
geposted Fri 11 Sep 20 @ 10:23 pm
so now if i repeat the same steps twice i.e right click a song vdj crashes and stay closed..heres a report if anyone can help i would appreciate it as i'm supposed to work tonight a social distance party thanks
Source
VirtualDJ
Summary
Stopped responding and was closed
Date
9/11/2020 4:49 PM
Status
Report sent
Description
A problem caused this program to stop interacting with Windows.
Faulting Application Path: C:\Program Files\VirtualDJ\virtualdj.exe
Problem signature
Problem Event Name: AppHangB1
Application Name: virtualdj.exe
Application Version: 8.5.6100.0
Application Timestamp: 5f565365
Hang Signature: 4165
Hang Type: 134217728
OS Version: 10.0.19041.2.0.0.768.101
Locale ID: 1033
Additional Hang Signature 1: 4165ba14042688df75f3eccca69f2710
Additional Hang Signature 2: 125d
Additional Hang Signature 3: 125dc82ee640c8a2935d01552f2847c4
Additional Hang Signature 4: 4165
Additional Hang Signature 5: 4165ba14042688df75f3eccca69f2710
Additional Hang Signature 6: 125d
Additional Hang Signature 7: 125dc82ee640c8a2935d01552f2847c4
Extra information about the problem
Bucket ID: d0700e5c1a07064ff81509f8ff2917c4 (1735304196458616772)
Source
VirtualDJ
Summary
Date
9/11/2020 4:49 PM
Status
Report sent
Description
Problem signature
Locale ID: 1033
geposted Fri 11 Sep 20 @ 11:23 pm
so the intel graphics driver is the problem. using a generic driver i ran last night but kept getting a loud noise coming out the speakers whene it freeze now but its not closing . help would be appreciated ...im sure theres quite a few crash logs that can help determine whats going on ..got me looking bad over here smh
geposted Sat 12 Sep 20 @ 2:58 pm
went back to vdj 2020 B5874 installed to a different folder and everything works .decided to let it update jus to see what happens and it updated and everythings working ..so far . gonna hook up a do a test run later .but no crashing of the program . was getting worried i should take the computer back ,but according to my reading my specs should be fine
dell g3 15 3500 (released 7/2020) new out the box from Dell,inc
i5 10300h @2.50ghz
16gb ram
intel uhd graphics card (630)
nvidia geforce gfx 1650
256gb ssd
i5 10300h @2.50ghz
16gb ram
256gb ssd
geposted Mon 14 Sep 20 @ 12:46 pm
ha!! lol just here talking to myself;self diagnosing my problems ..
shout out to my 88 views on here , haha
might help someone other than me ,who knows .
so 3 days of installing ..uninstalling drivers ,changing settings to settings.old , being told computer doesn't work with stems (even tho stems load in 2/3 secs before program just start freezing audio randomly then crashing on me ) something must was missing from within the install.
i compared the 2 install locations (original was named virtualdj so i named new install virtualdj2020 )
the original folder had one file : virtualdj.exe.temp
new folder has 2 files : virtualdj8.exe and virtualdj.visualelementsmanifest.xml
after seeing this i simply deleted the old folder and renamed the new folder .opened program and so far so good i can click without it crashing now will test for the freezing later today after kids get done online schooling
geposted Mon 14 Sep 20 @ 1:00 pm
Update : I did a complete restart of windows twice .I got rid of all dell apps and preloaded apps. installed drivers with driver easy ,intel ,and nvidia .I also bought a cooling pad since Dell has the fans locked so they supposed to come on when needed and there's no way to control them manually.
So far so good first weekend with no problems ,it felt good not to stress . seems i have to play around in audio settings to get headphones to work though everytime
P.S The preconfigured audio settings are never right when i select what i'm using and hit apply (tracktor z2, mcx8000,or denon ds1) i always have to go in and reselect inputs and outputs ..weird
geposted Mon 12 Oct 20 @ 2:19 pm
