Topic: Virtual Dj not installing
Virtual Dj wont install on pc , it keeps asking me to make sure I have access to the directory.
geposted Sat 12 Sep 20 @ 1:25 am
if you right-click that installer file you downloaded, is there an option at right-click menu that says "Install as Administrator"?
IF so, try that.
And if not, perhaps you are logged into a Windows account without privileges to install programs.
geposted Sat 12 Sep 20 @ 3:01 pm
Hi Norman there is no run as admin , only install repair and uninstall. I can install other programmes with no problems. For eg. I'm able to install (Rekord box, Ableton ). Not sure why vdj all drivers are upto date aswell.
geposted Sat 12 Sep 20 @ 8:38 pm
Try a computer restart, just in case the virtualdj.exe process is taken/in-use in the background (frozen process).
Worth a try ;-)
geposted Sat 12 Sep 20 @ 8:46 pm
