Topic: HOT CUE
How to restore Hot Cue. My Virtual Dj got crashed. lost all my Hot Cues. how can i restore them back
geposted Mon 21 Sep 20 @ 12:41 pm
They are in the database.xml file under documents/virtualdj
If that is broken, hopefully you have a backup you can restore
It may also just be locked by a dead process, in which case a simple laptop reboot should fix it
geposted Mon 21 Sep 20 @ 2:05 pm
Klaus sir thank you so much... DO i have to uninstall my software again?????? I TRIED ITS NOT WORKING...
geposted Mon 21 Sep 20 @ 2:11 pm
No. If you uninstall it and remove all files you also loose the hotcues
It's all about the database.xml file
geposted Mon 21 Sep 20 @ 2:30 pm
