Topic: Renaming a file with precomputed stems
NicotuxHome userMember since 2014
Renaming a file with pre-computed stem only rename the original file, not the .vdjstem one
(i.e. adding .vdjstems to filelist shows the .vdjstems as missing because reference original is missing
original is already tag as has_stems, and goes on reading them because generated stems didn't change)
would be fine it does, (the same way cdg + mp3 and .vdjedit)
it would be more simple to see out of VDJ and external drive
and would get good infos when folder is scan again on another computer (or recreating database)
geposted Tue 22 Sep 20 @ 2:42 pm
Works fine here, when renaming within vdj the vdjstems is renamed as well, just like with cdg.
geposted Tue 22 Sep 20 @ 3:24 pm
yes, side effect of not refreshing the list but refreshing list entry status ^^ need to go out and back to see it was done
geposted Wed 23 Sep 20 @ 8:43 am
It doesn't really make sense to add vdjstems to the file list in the first place though...
geposted Wed 23 Sep 20 @ 1:00 pm
