Hi all,
I have two CDJ-2000s and a DJM-900 NXS connected to Virtual DJ Pro, but the inputs from the mixer don't map to Virtual DJ, i.e. if I move the inputs on the DJM-900, it doesn't show up on VirtualDJ. I have used this exact same setup before and not had this issue. Does anybody know why this would be happening? I've attached screenshots of my settings.
Thanks in advance everyone!
geposted Tue 22 Sep 20 @ 11:22 pm
On DJM900NXS, MIDI does not start automatically. There's a "MIDI" button you need to press first.
Check this page for "M" button:
https://www.virtualdj.com/manuals/hardware/pioneer/djm850/layout.html
It's for DJM850 but if I remember correctly it's exactly the same on DJM900NXS as well
geposted Wed 23 Sep 20 @ 9:03 am
Thanks so much! I feel so dumb now - was using the NXS2 previously and I didn't have to do this
geposted Wed 23 Sep 20 @ 4:52 pm
