Hi do you know when this option will be added to the current skin vdj 2020 and 2021 ? I have an open ticket but i have no news
geposted Fri 25 Sep 20 @ 2:53 pm
Bien venu au club, je suis dans le même cas que toi ....
geposted Fri 25 Sep 20 @ 3:44 pm
It selects if the vu meter shows the level before the level fader (as default with most mixers) or after (so it will show silence if the level fader/crossfader is down)
geposted Fri 25 Sep 20 @ 4:07 pm
The user had the choice of what to select
geposted Fri 25 Sep 20 @ 5:18 pm
We had the choice in 2018 and we need the choice now too . It's a user selection
geposted Fri 25 Sep 20 @ 5:19 pm
There is no plan currently to add this in the 2020 skin, it is however not very difficult to modify the 2020 skin yourself and change this.
geposted Fri 25 Sep 20 @ 5:26 pm
ii spoke to support and they told me they would add it .
Why
not re add something that was already there ?
How do we add it by modifying the skin exactly ?
geposted Fri 25 Sep 20 @ 8:29 pm
I have add it in my Skin , I can change it in the Mixer Options (little Button over the Crossfader).
I find it also userful the VUs to change for what I need , when I work ;-)
My Controller has also this VU Option on the Channel VU.
Its a good practical thing :-)
geposted Fri 25 Sep 20 @ 9:10 pm
How did you add it
geposted Fri 25 Sep 20 @ 9:39 pm
This is not something trivial, needs some work
here is a generic example of the structure (extracted of 8 decks skins) of the mod :
<define class="vb_vumeters" placeholders="*x,*y,*width,*height=[WIDTH]*4,*deck=0,chan=">
<group name="vumeter[DECK]" x="-[WIDTH]/3+[X]" y="[Y]">
<square x="-5" y="-5" width="[WIDTH]*5/12" height="[HEIGHT]+10" color="vb_vumeterbg" radius="6" />
<menu width="11+2+11" height="[HEIGHT]+10">
<item text="Show vu meter" action="skin_panel 'vu_output[DECK]' on" check="skin_panel 'vu_output[DECK]'" />
<item text="Show output levels" action="skin_panel 'vu_meter[DECK]' on" check="skin_panel 'vu_meter[DECK]'" />
</menu>
<panel name="vu_meter[DECK]" group="vumeter[DECK]" visible="no">
<visual source="deck [DECK] get_vu_meter_left [CHAN]" class="vb_vumeter" width="[WIDTH]*5/12" height="[HEIGHT]"/>
<visual x="+13" source="deck [DECK] get_vu_meter_right [CHAN]" class="vb_vumeter" width="[WIDTH]*5/12" height="[HEIGHT]"/>
</panel>
<panel name="vu_output[DECK]" group="vumeter[DECK]" visible="yes">
<visual source="deck [DECK] get_level_left [CHAN]" class="vb_vumeter" width="[WIDTH]*5/12" height="[HEIGHT]"/>
<visual x="+13" source="deck [DECK] get_level_right [CHAN]" class="vb_vumeter" width="[WIDTH]*5/12" height="[HEIGHT]"/>
</panel>
</group>
</define>
adapt (for a one master deck : remove all deck references and position computation and & copy <visuals>...</visual> and x="" y="" from your skin)
i.e. in default/:essentials skin
line 1408 for mixer
line 1430 for video
</menu>
</panel>
</panel>
</group>
</define>
line 1408 for mixer
line 1430 for video
geposted Fri 25 Sep 20 @ 10:25 pm
What ?
</menu>
</panel>
</panel>
</group>
</define>
line 1408 for mixer
line 1430 for video
What ?
</menu>
</panel>
</panel>
</group>
</define>
line 1408 for mixer
line 1430 for video
geposted Fri 25 Sep 20 @ 10:32 pm
Mastermc789 wrote :
How did you add it
How did you add it
Have use it from the 2018 Skin...
geposted Fri 25 Sep 20 @ 10:38 pm
Mastermc789 wrote :
How did you add it
How did you add it
I thought you said you added it .
geposted Sat 26 Sep 20 @ 2:22 am
Mastermc789 wrote :
How did you add it
How did you add it
Yes , I add Id from the 2018 Original Skin , in my Skin XML ;-)
geposted Sat 26 Sep 20 @ 4:58 am
Please, can everybody stop quoting (and nesting) entire messages from previous posts, when the post is immediately above, and it's obvious who you're replying to?
Thank you
Thank you
geposted Sat 26 Sep 20 @ 8:20 am
Mastermc789 wrote :
How did you add it
How did you add it
No idea what you mean
geposted Sat 26 Sep 20 @ 1:13 pm
I'm sure to you that's hilarious.
Chances of me helping you modify the skin now = zero. Well done.
geposted Sat 26 Sep 20 @ 1:50 pm
Ok
geposted Sat 26 Sep 20 @ 9:08 pm
