So this is a weird one. Maybe someone can help?
Using the VideoCube video effect. If you use it manually, NO PROBLEM. 100%
However, trigger it with an external device and while the small CHANNEL preview window looks fine, the OUTPUT on both the VDJ window and secondary output jitter like crazy. If you STOP the video, the JITTER STOPS and it works but when you play a video, it goes to hell in a hand-basket. Very weird.
Using V8.3 4592 and no, don't want to upgrade.
Any ideas? Here's the video: https://youtu.be/DmQMh_S7190
geposted Sat 26 Sep 20 @ 5:15 am
So this is intermittent. I ran one show where it was fine....
geposted Tue 06 Oct 20 @ 4:32 pm
