Maybe someone has an idea to help me. I stream via digistream to Second Life from an IMAC PRO on the new VDJ 2020, using a 6 turntable skin. I've been using VDJ for 7 years and this is a new problem I can't solve. A song from the last time I changed the *Broadcast Song Info* is displaying when I play the first song. *Broadcast Song Info* is set to NO. If I toggle *DisplaySongInfo* a few times, it will pick up the next song and display that one at the beginning of the set, until I toggle again. No other songs are displayed. Should I report this as a bug or is there something I do not see, that needs to be changed. All video options are turned off, so that is not a solution. Thanks to anyone who wants to give it a try!
geposted Sun 27 Sep 20 @ 10:33 pm
its probably cached by the radio server might try and do a restart on radio server or clear cache if it has that option
geposted Sun 27 Sep 20 @ 10:55 pm
Thanks Wicked, that might be it! I'll see what can be done from them.
geposted Mon 28 Sep 20 @ 12:29 am
