Hi, I'm using v8.5 b6106 on the Prime 4 with stems EQ mode and frequencies on outer channels selected. Otherwise default settings.
I'm having 2 issues:
1. When I use the Sweep Fx knob on the outer channel, it only works for the 'noise' effect. The other 3, filter, echo, wash are do not work.
2. Crossfader does not work. When I use the physical knobs, it reflects on VDJ, but no audio change between channels.
Help appreciated.
Help appreciated.
geposted Sat 03 Oct 20 @ 8:14 pm
