Topic: resend virtualdj 2021 pro infinity
i paid online for virtualdj pro infinity and i have the license but I'm stuck on demo virtual 8
geposted Mon 05 Oct 20 @ 10:28 pm
login using the forum user and password and you will be fine
geposted Mon 05 Oct 20 @ 11:59 pm
no one needs to call you. just open Options, type in the word demo in the search box and turn off demo mode
after that - strongly recommend reading the manual and watching the tutorial videos
geposted Thu 08 Oct 20 @ 6:33 am
Actually you can't turn off shop demo mode from options, once you've enabled it - as that would defeat the object of having a demo mode.
If indeed that's what OP has done, there's a message on screen which explains this at the time. The settings.xml file needs deleting or editing to reset it.
Being here since 2012 and having no idea what logging in means - priceless.
geposted Thu 08 Oct 20 @ 7:48 am
geposted Fri 21 May 21 @ 4:04 am
delete settings.xml in /documents/virtualdj/
Then start the software. (if you are in shop demo mode)
geposted Fri 21 May 21 @ 7:05 am
