Hey
I use Virtual DJ since the firsts versions (I started with mythologic Atomix..)
I Know that softwere as well; & I check for the updates all the time.
at the last versions, i found a problem that repiting iself.
after 10 minutes of playing (+\-) one of the Decks "loose" the bass ; Suddenly it plays like filterd . if I put the same track in another deck it goes well ; and play it clear.
somehow other have a related problem?
somehow know what is the reson?
thank's from now to the helpers..
geposted Wed 07 Oct 20 @ 10:11 am
