Error in extension options.
Firstly, it would be nice if you can only download something via the program that it recognizes when you have already installed certain effects, for example. sorted them into different sub-folders.
It does not recognize effects as installed if they are not sorted in the main folder but in sub-folders.
Second, if I then download an effect and want to move it to one of the sub-folders, it does not move the respective effect and replaces the existing one.
It is only possible in Windows Explorer, but not with the function to move in the program.
geposted Mon 12 Oct 20 @ 5:22 am
