Something that has always bugged me when I get to wanting to do some manual deduping of files. The Dupes filter seems to really only catch some things. For instance, I know when it pops up a pair of dupes and I know that there are more. So I will search and it's never initially caught in the filter. And we are talking identical titles, artists, even album title.
Just never quite understood why it's fuzzy logic can catch variants pretty well but then always seems to miss some.
geposted Mon 12 Oct 20 @ 6:19 pm
Any thoughts?
geposted Fri 23 Oct 20 @ 4:15 pm
You are checking in the duplicates By Tag subfolder?
geposted Fri 23 Oct 20 @ 4:16 pm
That is correct. The fuzzy logic just seems to miss on things and I can't really pin anything on it. Similar file sizes, sometimes 100% identical to others other than maybe file path.
geposted Fri 23 Oct 20 @ 4:25 pm
Can you check the remix column as well?
The instrumental would indeed not be found as a duplicate, but the other one should, unless it's a remix by the remix field.
geposted Fri 23 Oct 20 @ 4:32 pm
Here is another example since I already manually pruned those files.
I'll be damned, it was the remix tag...
geposted Fri 23 Oct 20 @ 4:41 pm
