Hi,
waveUseFrequency option have no effect (VIRTUALDJ 6106 - MAC OSX)
No effect on colors Waves or Shapes......
Please check
Regards,
O.
Please check
Regards,
O.
geposted Mon 12 Oct 20 @ 7:12 pm
This is for the Colored Songposition Waves in the Players , not the Waves on Top ;-)
geposted Tue 13 Oct 20 @ 8:36 am
It would be cool and nice to have this for the main WAVE on TOp like REKORDBOX or ENGINE PRIME :)
So difficult ? to do 3 colors with Frequency and not stems ? Blue/Green/white (DENON) or Blue/orange/white(Pioneer) (BASS/MED/HIGH)
don't understand why it's not added, like REKORDBOX 3 BANDS or DENON ENGINE PRIME
geposted Tue 13 Oct 20 @ 8:43 am
I agree, the three colour frequency based waves have become "industry standard" now.
Another issue with the shapes waveform was reported here, where bass is not shown on the waveform.
geposted Tue 13 Oct 20 @ 8:56 am
There Skins they have the Pioneer or Denon Style Waves you can Change.
Look at the Project X Skin.
geposted Tue 13 Oct 20 @ 11:55 am
Changing color in the xml in skin can be done on any skin ;-)
But think the original poster meant using frequencies instead of stems for the 3band, and that is currently not supported
geposted Tue 13 Oct 20 @ 12:04 pm
Yes, it's not only a 3 color problem (XML), but to have the choice to use STEM or Frequency... :)
Sure, it will be supported soon :)
geposted Tue 13 Oct 20 @ 12:11 pm
Ideally the separate bands would be linked to the EQ crossover frequencies chosen in the config too.
geposted Tue 13 Oct 20 @ 12:26 pm
