my music hard disk died, and i had to buy a replacement drive
it was a SATA internal drive and i have replaced it with a new one, but currently its connected via USB-SATA cable and within the next week or 2 i will have it installed inside the computer
my music was backed up a few months ago, so my music collection is a few months out of date
but i have the database, which i emailed to myself the day my drive died
and i have re-downloaded all of the music i had been collecting since the last backup
so my plan is to see whats missing from the database and then replace the files
heres my problem, VDJ doesnt seem to be recognising the database. all of my music is coming up as "first seen = today"
and all my playlist songs are showing as "missing"
also VDJ seems to be creating a database folder on the new drive, i dont know why its doing that, because i always have that file in 'my documents'
there is no option in virtual dj to tell it which database file to read.
and the folder tree and drive letter is correct, so its not a folder tree/driver letter issue.
do you have any reccommendations as to what i can do to sort this out please?
geposted Mon 12 Oct 20 @ 7:21 pm
If you have it connected via USB then your computer (and VDJ) will see it as an external drive - so VDJ will put the database there.
geposted Mon 12 Oct 20 @ 7:28 pm
ok but if i replace that database file with my old database file, it still doesnt read it ,for some reason
the music still appears, as it would in a blank database
geposted Mon 12 Oct 20 @ 7:34 pm
You may have to do a find and replace on the file paths in the database to reflect the new location of your media files.
geposted Mon 12 Oct 20 @ 7:48 pm
its the same D:\Music\[ DJ FOLDER ]\[ MUSIC ]
if i open the tag editor on existing songs, it comes up the same
geposted Mon 12 Oct 20 @ 7:59 pm
