I have karaokes and some of them have no music in the beginning and have text in the beginning. VirtualDJ decides to skip the silence and go straight to the music. how do i fix this?
geposted Wed 14 Oct 20 @ 9:25 pm
Go into settings and look for karaoke skip silence and click yes or if you don't want to skip silence click no I have just looked and that is all I found I hope this will help.
geposted Wed 14 Oct 20 @ 9:34 pm
thanks but that isnt working for me
geposted Wed 21 Oct 20 @ 10:18 pm
If you already checked karaokeSkipSilence in settings, also check the autoCue setting. . if you set that to "no"
geposted Wed 21 Oct 20 @ 10:23 pm
