Hello
I've recently bought an hp gaming laptop and can't seem to make CMD Studio 4a work with vdj. I've tried both the 1.5 and the 1.7 drivers for it on the official page, but I get an exclamation point in Device Manager on it. I cannot use it as a soundcard, nor as a controller.
Anybody has encountered this issue? I'm using Windows 10, latest vdj. Tried all power plans, tried updating windows - no luck.
Thanks
Thanks
geposted Wed 21 Oct 20 @ 8:27 pm
Could be it doesnt have compatible drivers with Windows 10. But hopefully it is...
The latest driver seems to be 1.7 (that you probably already tried as you said)
https://mediadl.musictribe.com/download/software/behringer/CMD/CMDStudio_ASIO_Driver_v1.7.0.zip
Maybe try other usb port and other usb cable.
Also., try install the driver FIRST, then connect the controller.
(and possibly remove what you already installed as driver, to start fresh)
geposted Wed 21 Oct 20 @ 8:46 pm
It's not about drivers if you get an exclamation mark in Device Manager, that's why you cant use it even as a MIDI controller.
Try to use different USB port, different USB cable, powered USB hub.
geposted Wed 21 Oct 20 @ 9:23 pm
Thanks, but the laptop is a pretty good one. I don't think it's a problem with the usb power. Any other ideas?
geposted Thu 22 Oct 20 @ 10:05 am
What reason does Windows give for the exclamation mark on the CMD device?
Check 'device status' window (see below).
https://www.windowscentral.com/how-fix-yellow-exclamation-mark-device-manager-windows-10
geposted Thu 22 Oct 20 @ 10:11 am
Thank you. It's a code 10 "insufficient system resources exist to complete the api"
geposted Thu 22 Oct 20 @ 4:28 pm
I wonder, do you have a Logitech webcam?
Apparently one cause of this message is UpperFilters and LowerFilters entries in the registry, and Logitech webcams are known for this.
geposted Thu 22 Oct 20 @ 4:41 pm
Nope. It's a hp truevision cam (this is a laptop)
geposted Thu 22 Oct 20 @ 5:35 pm
You might still want to check through the registry for those upperfilter/lowerfilter entries.
geposted Thu 22 Oct 20 @ 5:52 pm
Did you try other port?
The few times i had hardware give such an error, usually its been cause i connected hardware before the drivers were installed, and I guess Windows attempted some generic driver that didnt work...
Connecting to new usb, will "refresh" driver for that port.
But been ages since I saw such an error, must have been back in Vista days ;-) could be remembering wrong
geposted Thu 22 Oct 20 @ 7:03 pm
I've read about these, but it said they should be under the guid class of the actual controller, not under another device, as I think you're suggesting. I've identified the entry for the controller, but it doesn't contain the upperfilter etc.
geposted Thu 22 Oct 20 @ 8:02 pm
You need to check the whole registry.
If there are entries for upperfilter and lowerfilter (anywhere in the registry) it can cause issues for other devices.
Sometimes you can just remove the entries, install the problem driver, then reinstate the entries.
geposted Thu 22 Oct 20 @ 8:21 pm
I don't think it's a good idea, given that this guy cannot boot after removing upper\lower filters for the wrong devices: https://answers.microsoft.com/en-us/windows/forum/all/inaccessible-boot-device-after-deleting-upper-and/110b4128-904b-46a3-b573-09cd836bfe30
geposted Thu 22 Oct 20 @ 10:56 pm
As always, editing the registry is done at your own risk, and something you maybe should avoid if you're not confident in your abilities.
He was particularly unlucky, but I did mention this procedure because I have successfully used it myself in the past to solve problems.
The choice is yours.
geposted Fri 23 Oct 20 @ 8:01 am
Well, guess what.
I've installed a fresh windows 10 on an external drive, and I get exactly the same issue. So it's a hardware problem. The only possibility that remained imo is that it needs more RAM, but it's ridiculous - there's already 3.5gb available. I'd like to still try disabling the 2gb the stupid HP system is forcefully allocating for the iGPU (I have a dedicated one) and see if that solves it. Didn't find any clue on how to do that or if it's even possible. I'm pretty lost
geposted Fri 23 Oct 20 @ 2:39 pm
Got a chance to test the controller on other computer? yours or a friend.
Just to rule out the controller is broken...
geposted Fri 23 Oct 20 @ 2:40 pm
Did you check through the registry? You post on here asking for help, then choose to dismiss the suggestions.
If you pay attention to the drivers available, you'll notice that Windows 10 compatibility is not mentioned. Therefore, the best test is to try installing on an older computer that has an OS that is supported by the drivers - Windows 7 or 8 for example.
geposted Fri 23 Oct 20 @ 3:04 pm
There are known problems with some old audio drivers/devices and USB 3.x : problem is USB 3 does not have constant flaw
Numark, Beringher, Hercules,... are affected
only solution found : plug it in usb2 port ... if any
Other thing, sometime as groovindj said driver have not Windows10 compatibility (created before win 10)
and even they would work, win10 takes "updated" default instead of correct older driver
this have a solution:
https://docs.microsoft.com/en-us/windows-hardware/drivers/audio/usb-audio-not-playing
geposted Fri 23 Oct 20 @ 3:11 pm
Already done that. My lap and pc at home are working fine
geposted Fri 23 Oct 20 @ 4:17 pm
Please translate.
Does that mean you tried the CMD on those computers and it works?
geposted Fri 23 Oct 20 @ 4:20 pm
