On my DDJ-1000, on the decks 3 and 4, the default pad mode is Stems, whereas it's Hot Cue for 1 and 2.
This causes me to occasionally turn off one of the stems when attempting to hit a hot cue and not noticing it, then i switch to hot cue and play but i don't have a way to bring the stems page back (which i also don't need since i use the mixer for stems).
How can i make Hot Cue the default pad mode for all decks? I can't find it in the settings.
geposted Sun 25 Oct 20 @ 6:26 pm
In the skin you can right-click the pads drop down (or the 4 buttons above the pads if thats the view), and assign what should be at the controller
https://www.virtualdj.com/manuals/virtualdj/interface/decks/decksadvanced/pads.html#controller
geposted Sun 25 Oct 20 @ 7:49 pm
That's already configured.
I start VDJ, it's Stems on Decks 3 & 4, but when i press the Hot Cue Pad Mode Button (the first), it switches to Hot Cues. I have no idea why it's set to Stems in the first place, i don't have it assigned to any of the Pad Mode pages.
geposted Sun 25 Oct 20 @ 10:06 pm
You set deck 3 and deck 4 explicitly to hotcue as in the image above? Should work. Might be a bug if not
geposted Sun 25 Oct 20 @ 10:35 pm
I've noticed my RP8000Ses start on stem mode by default. It's perfect, wouldn't change a thing, and slightly afraid that one day it'll stop doing that, because the default page config applies to my 72 so I'm not sure how to set the page on the RP8000Ses.
geposted Mon 26 Oct 20 @ 1:30 pm
Please, take a look for yourself:
geposted Mon 26 Oct 20 @ 8:42 pm
