the software is asking for the serial number
geposted Mon 26 Oct 20 @ 4:12 pm
....and what exactly is "the software"? Which version of VirtualDJ are you trying to use?
The standard versions of VDJ 8 don't use serial numbers.
geposted Mon 26 Oct 20 @ 4:18 pm
Sounds like you might be using a very old version of VirtualDJ.
Better to update to latest and greatest: https://www.virtualdj.com/download/
And for license for extended use: https://www.virtualdj.com/buy/
(no serial number, just login needed)
geposted Mon 26 Oct 20 @ 4:20 pm
