Wanting to up the Hercules Inpulse 300 or the Pioneer DDJ-SB3. Coming from Hecules RMX from years ago...2006.
Just wondering which controller works with all the functions Virtual DJ has to offer. Will be purchasing VDJ license as soon as I figure out what controller to get. Cant wait!
Thank you so much!
Andre Surmeyan
Thank you so much!
Andre Surmeyan
geposted Wed 28 Oct 20 @ 4:29 pm
Both controllers works well with VirtualDJ.
And they are quite similar. Either choice will be fine, choose the one you prefer.
Can look at the manual links below to what feature each of them have as far as buttons, sliders, knobs and functions goes.
Hercules Inpulse 300:
https://www.virtualdj.com/manuals/hardware/hercules/inpulse300/setup.html
Pioneer DDJ-SB3
https://www.virtualdj.com/manuals/hardware/pioneer/ddjsb3/setup.html
Pioneer DDJ-SB3
geposted Wed 28 Oct 20 @ 6:14 pm
I wouldn't recommend either of those controllers, to be honest.
They both have very short pitch faders, placed out of reach at the back of the controller, and a lack of FX parameter knobs.
I did post this before in another thread, where the same question was asked - but an over enthusiastic "support" person has removed the entire thread (which was more established than this one) including that answer, and removed my previous post in this thread about it being a duplicate.
geposted Wed 28 Oct 20 @ 6:35 pm
Thanks for your Atomix for the input and the info!
Groovindj, could let me know what you would recommend instead. One with FX parameter knobs would be good.
Sorry it was deleted.
Thanks again
Thanks again
geposted Wed 28 Oct 20 @ 7:50 pm
What's your budget? Mixars Primo seems to be the cheapest with the full set of FX knobs and long pitch faders.
Numark NV II if you want screens too.
geposted Wed 28 Oct 20 @ 7:55 pm
Both the SB3 and and the Inpulse have FX param knob.
The first knob of any effect is usually the significant one to adjust on the fly during the mix.
Usually called wet/dry or strength and similar..
The other fx params are very often just adjustments that you dont use on the fly, but rather adjust once or twice to get the sound you want.
Besides the SB3 is one of the most used controllers with VirtualDJ,. and many thousands of users are happy with that.
All depends on your budget and needs
geposted Wed 28 Oct 20 @ 8:00 pm
If you want to consider something else in same price range ish. Say around $300 or so...
- Pioneer DDJ-400
- Numark Mixtrack Platinum FX
- etc etc
https://www.theguitarjunky.com/best-dj-controller-under-300/
https://wearecrossfader.co.uk/blog/best-beginner-dj-controller-under-300/
Just check out some youtubes, reviews and find one you like.
That suits your budget and needs :-)
- Pioneer DDJ-400
- etc etc
geposted Wed 28 Oct 20 @ 8:05 pm
They're also used for the multi-FX mode in VDJ.
geposted Wed 28 Oct 20 @ 8:09 pm
Wow Thanks for the Responses!!!
Budget is probably $450 Max.
geposted Wed 28 Oct 20 @ 8:38 pm
Ok last question.
The Numark Mixtrack Platinum FX or fx pro look right up my alley
They work well with virtual dj functions as well.?
Sorry for all the questions.. have been out of the game for a while.
geposted Thu 29 Oct 20 @ 1:16 am
