Since the last update to version 8.5 b6150, there is a problem with the display of the Waveform on the controller screen.
In my case the Rane 72 screen
I change the controllerwaveformzoom nothing change still not showing waveform anymore when two songs is loaded
Have you noticed this too even on another controller with display screen?
everything worked fine just before.
Still work on Serato. Probably a software issue with the update
geposted Mon 02 Nov 20 @ 2:39 pm
I think a special early access release has just been released to fix this problem:
BUILD 6154 (2020-11-03)
-Fix Rane 72 waveforms broken in previous update
geposted Tue 03 Nov 20 @ 9:31 am
You can try the update already if you run this installer as update
https://www.virtualdj.com/download/pc/ea (Windows)
https://www.virtualdj.com/download/mac/ea (macOS)
See if that fixes it ;-)
geposted Tue 03 Nov 20 @ 11:07 am
YES work perfecty know
Good Job guys
look like better than before.
Anyway still better than SERATO so far :-) look
Thank you
Good Job guys
Thank you
geposted Tue 03 Nov 20 @ 5:10 pm
ola, gostaria de uma solucao quando uso a rane 72 com o virtual dj ligado no A usb canal, e mudo a chave para B usb onde esta ligado outro software, o virtual dj nao responde mais a rane twelve, alguem pode me ajudar....
geposted Tue 15 Mar 22 @ 2:06 pm
