Quick question
Can a Pad Page be set to Favorite, as indicated in manual?![](/img/324034/36984/PADS MODE FAV.png)
And listed here in manual as are Pads options.
![](/img/324035/24036/PadPages Manual.png)
But current VJD v6154, has this view for Pads Editor:
NOTE Missing Favorite check box.
And the current options for Pads are:![](/img/324037/72910/PADSPAGES OPTIONS.png)
Note Missing padsPagesFavorite option and the undocumented padsPagesOrder
Is the padsPagesOrder replacing Favorites?
And if so, How does one use it?
EDIT: THE ANSWER:
One can Drag the order of each Pads Page, in the Pads Editor to create any order you wish.
So simple, LOVE it
Thank you
EDIT: THE ANSWER:
So simple, LOVE it
Thank you
geposted Thu 05 Nov 20 @ 1:33 pm
