Hi
With my Prime 4, my question is in regards to the Talkover function:
How does VDJ treat this function?
It works, but are the settings based on the configuration natively on the P4 ? or are there adjustments that can be made in VDJ ? or both ?
Thanks
Thanks
geposted Thu 05 Nov 20 @ 8:39 pm
I'm kinda wondering the same thing, but with my DDJ-1000 (which is not too different since the Prime's standalone functionality doesn't play a role here).
Since the deck effects are software and the mic effects hardware, and because there is a DNC mapping entry to communicate to the controller which zeroDB the mic is set to, it appears to me that the talkover is processed by the hardware and not VDJ.
geposted Fri 06 Nov 20 @ 10:47 pm
Its hardware only mic., so everything is controlled and operated in hardware
https://virtualdj.com/manuals/hardware/denon/prime4/layout/mic.html
( http://virtualdj.com/manuals/hardware/pioneer/ddj1000/advancedaudio.html#mics )
Unique for the Prime 4 is that it also sends midi signals, so you can script/map something to happen on use.
But not really recommended since hardware will still operate on its own, and have no impact in that regards
![](/img/324130/27275/talkover.png)
geposted Sat 07 Nov 20 @ 12:47 am
Excellent, thank you for the clarification !
geposted Sun 08 Nov 20 @ 12:14 am
