this build is crashing when i set action cues while a track is playing
going back to 6106 as its happening often
might even have a crash report in there
also another issue I've been having for a very long time - if i move something on my controller close to the time an action cue should activate it doesn't activate at all
geposted Sat 07 Nov 20 @ 2:48 pm
It crashes on me with the first use after hours of inactivity. 1st click freezes, 2nd click crashes.
geposted Sat 07 Nov 20 @ 4:10 pm
crashing when i set action cues from the macro box, wenever the track is playing or not, loaded or not
geposted Sat 07 Nov 20 @ 4:44 pm
"crashing when i set action cues from the macro box, wenever the track is playing or not, loaded or not"
Same here. Crashes and then restarts. When it crashes after several hours of inactivity it does not restart automatically.
geposted Sun 08 Nov 20 @ 1:20 am
does BUILD 6156 include a fix for this?
geposted Mon 09 Nov 20 @ 8:02 pm
yes, not mentioned in the public release notes but it is mentioned with E.A.
geposted Mon 09 Nov 20 @ 9:11 pm
thanks was afraid to update
geposted Tue 10 Nov 20 @ 12:48 am
