Hi
If your microphone is ON then you use Talk over, on release the microphone defaults to off.
Is there anyway this can default to ON, or to the state it was in before the Talk over button was pressed.
Is this just a case of adding some code to the xml file , if so can anyone give me an example of the code to use
Thanks
Pete
Thanks
Pete
geposted Sun 08 Nov 20 @ 1:09 pm
