Topic: Platinum Fx browser button
Man..I feel like i'm being a pest now... On The Platinum Fx , after playing awhile sometimes the browser button click won't move from the folders to the files. I have to use the mouse to click into the file section of the browser and then use the browser knob. The interesting thing is when I close VDJ and restart, it works again? Am I doing something wrong? please assist and thank you..
geposted Sun 08 Nov 20 @ 8:56 pm
Could be the shift button is on...
But i guess its not an on/off button, but rather on while pressed only.
But you can try, next time it happens, if you click shift, if it works again.
(at least the only thing in mapper that changes the browser button click to only be folder, is the shift button being active, so maybe the shift get "stuck" somehow)
And if you never use shift + browser button click,. you can even remove it, to see if that helps
Simply set SHIFT_BROWSER_PUSH in mapper to action : nothing
But I guess you use it for opening closed folders (and thats what its for, as mapped by default)
geposted Sun 08 Nov 20 @ 11:13 pm
I won't mess with the mapping.I have a touch screen laptop so i guess in a pinch, i can click on that way...thanks
geposted Mon 09 Nov 20 @ 6:16 am
