Hello there,
It took me a while to get everything set up the way i like it,now everything works fine but theres one issue.
recording my microphones works fine,but id like it in a different format than the standard .vdjsample
I prefer FLAC but MP3 or so will do all well
Or if thats not an option,is it possible to convert .vdjsample to something else?
geposted Mon 09 Nov 20 @ 7:58 pm
SamplerExportLossess -> yes
geposted Mon 09 Nov 20 @ 8:00 pm
Thanks a lot!
Didnt think it would be that easy :D
geposted Mon 09 Nov 20 @ 8:15 pm
I just tried it,its still recording as .vdjsample :(
tried restarting Virtualdj but its still the same,even though it says its ON in the settings.
Also,it doesnt seem to record my 2nd mic just the 1st one.how can i fix this?
geposted Mon 09 Nov 20 @ 8:32 pm
SamplerExportLossess just changes between Ogg and Flac as encoder for samples.
They are still saved in .vdjsample format.
geposted Mon 09 Nov 20 @ 8:54 pm
Oh alright its not a big deal i can always convert them later.
Figured out why the 2nd mic wasnt recording.. it wasnt turned on LOL
Thanks for the help guys ;)
geposted Mon 09 Nov 20 @ 9:07 pm
