Topic: Shadertoy Timing Question
Is there any way to alter the timing of the shadertoys rotation when it's set to auto?
geposted Fri 20 Nov 20 @ 6:57 pm
Think it changes every 32 beats (usually songs change structure too around that)
Dont think there is any setting to change that, at least currently...
You can always map a button though, and change manually (in theory even automatically with a script that repeat itself as a "loop" )
deck master effect_string "shader" 1 +1
deck master effect_string "video" 1 +1
or if running as audio only visuals:
effect_string "audioonlyvisualisation" 1 +1
geposted Fri 20 Nov 20 @ 7:05 pm
Awesome, I'll try that, thanks :)
geposted Fri 20 Nov 20 @ 7:22 pm
Yay, that's perfect man, thanks a million!! I can turn off the auto-change and ONLY change it when I want via the kb !! PERFECT!!
geposted Fri 20 Nov 20 @ 7:24 pm
locodogPRO InfinityModeratorMember since 2013
there's also ZvideoControl, but that's based on changing on 32 or faster, and aimed at 2 deck shader stuff
geposted Fri 20 Nov 20 @ 8:07 pm
